Click to visit BT.com
BT.com
Wishlist
Qpad OM-75 PRO GAMING OPTICAL MOUSE - optical - 7 button - USB - white
Quicklinx: 8B5XWS00
Mfr#: OM-75
QPAD OM-75 Pro Gaming Optical Mouse
Features the award winning 5-finger grip
For most gamers, it's all about the feel, and this is where the QPAD OM-75 truly shines! QPAD OM-75 features the award winning 5-finger grip, a stylish white piano finish that is easy to keep clean and true CPI setting in the sensor. The reliable sensor technology, proven by millions of gamers, has undergone improvements for generations. QPAD OM-75 also features a micro control unit to optimize the tracking performance, pre-mounted Glidz on the feets for smoother and faster mouse movement, 7 buttons of which 5 are programmable for short cuts, keys and macro commands. You can move at a max speed of 1 meter per second without losing data performance.
The sensor pictures the surface with a shutter speed of 6469 frames per second covering an area of 30 x 30 pixels per frame. This generates an image processing of impressive 5.8 MB data per second. You will be able to adjust the USB polling rate between 125, 250, 500 and 1000 Hz depending on how much your computer port can accept without creating lag. The QPAD OM-75 is Plug and Play for easy installation, so no external drivers are needed. The QPAD OM-75 also contains on board memory that keeps your programmed settings, even when switching to another computer. In addition to all this, the left and right buttons are built to last an impressive 5 million clicks, and the QPAD OM-75 switch technology will provide you with a distinctive feedback, to make sure every click counts!
- Optical sensor technology proven by millions of gamers
- Comfortable ergonomic award winning 5 finger grip
- Plug & Play, no drivers needed
- Onboard memory that save your settings
Qpad OM-75 PRO - mouse - USB - white
Mouse
Wired - USB
White
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
1600 cpi
Performance
Up to 40 inches per second, 15 G maximum acceleration
Programmable buttons
1 x USB cable - integrated - 2 m
2 years warranty
Mouse
White
Input Device
Wired
USB
Optical
Buttons Qty
7
Movement Resolution
1600 cpi
Performance
1 x USB - 4 pin USB Type A
Plug and Play
2 years warranty
Service & Support Details
