Click to visit BT.com
BT.com
Wishlist
Qpad 5K Laser Gaming Mouse - 7 button - USB
Quicklinx: 8B5SWS00
Mfr#: 5K
High end gaming grade laser sensor
QPAD ®|5K™ features a powerful navigation engine, adapted for high performance laser navigation. It has been specifically designed for high-end professional gamers, and enables extremely high-speed motion detection and high resolution to provide precise tracking capabilities which are required for many of today's most popular gaming applications. QPAD®|5K™'s new laser sensor is ideal for gamers who require precise high-speed tracking on a variety of different surfaces.
"We have been planning to make a mouse for several years now. Until now the optical and laser technology hasn't lived up to QPAD standards. With this mouse we are setting a new standard for gaming mice. Just as with our headset this is a product which fits right into the premium segment of the market. I really enjoy playing with the QPAD ®|5K™, it works with the extreme high speed movments that used to be a huge problem for laser mice. QPAD ®|5K™ delivers a micro precision never seen before, and our 5 finger ergonomic shape is fantastic. The design of the mouse is shaped to fit a 5 finger grip and by doing this we make sure that you have as little friction as possible." - Says QPAD founder, Christer Körnbäck
- Five-finger gripp. Comfortable relaxing ergonomic grip
- High end gaming grade laser sensor, Gives a much more accurate movment than optical sensors
- 5 Programmable button and macro recording via software. On board memory that stores your settings.
- Plug & Play. No external drivers needed.
Qpad 5K - mouse - USB
Mouse
Wired - USB
12.5 cm x 4.2 cm
155 g
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
5040 cpi
Performance
30 G maximum acceleration, 12000 fps, 1000 reports per second, 150 inches per second, 10.8 megapixels per second, realtime sensitivity switching 90 - 5040 cpi
Programmable buttons, scrolling wheel, golden USB plug, braided cable, five finger grip
1 x USB cable - integrated - 2 m
2 years warranty
Mouse
12.5 cm
4.2 cm
155 g
Input Device
Wired
USB
Laser
Buttons Qty
7
Movement Resolution
5040 cpi
Performance
1 x USB 2.0 - 4 pin USB Type A
Plug and Play
2 years warranty
Service & Support Details
