BT.com
Wishlist
QNAP VS-2112PRO+ 2 Bay 12 Channel Desktop NVR NAS
Delivery
Standard Due date unavailable
Powered by the Intel dual-core processor, it delivers high performance at a throughput rate of 180 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 2-bay VS-2112 Pro+ is designed for the SMB and small-office/home office segment with the features of robust performance, solid reliability and high-definition local display.
The VS-2112 Pro+ can accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-2112 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
QNAP VioStor VS-2112 Pro+ NVR - standalone NVR - 12 channels
NVR - 12 channels - networked
IP Cameras Supported
12
Compression Format
MJPEG, MPEG-4, H.264
Image Resolution
1920x1080
Hard Drive(s) Supported
Quantity: 2
Voltage
100 - 240 V
10.2 cm x 21.8 cm x 15.4 cm
2.5 kg
Country Kits
Europe
NVR
Video Channels
12
12
Image Resolution
1920x1080
Compression Format
Package Content
Manual, DVR, software, cables, mounting kit, DVR key
Network cable - RJ-45 - RJ-45 - 2 pcs.
Software Included (Y)
QNAP Finder, Drivers & Utilities
Country Kits
Europe
VCCI, BSMI, FCC
Security DVR
Display Modes
6 split screens, 9 split screens, 8 split screens, 4 split screens, 10 split screens, 12 split screens
Playback Search
Date / time, event
Record Events
Alarm, scheduled, manual
Networked
RAID 0 support, RAID 1 support, JBOD support, watermark, Pan/Tilt/Zoom support, motion detection, key lock, security lock slot (cable lock sold separately)
Hard Drive
Quantity Supported
2
Serial ATA
Removable
DDNS Support
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UPnP, SMB, CIFS
Load balancing
Video Output Ports
HDMI x 1
Network Port
10/100/1000Base-T x 2
Other Ports
USB 2.0 x 4, USB 3.0 x 1
Voltage
100 - 240 V
Frequency
50/60 Hz
Power Consumption
39.3 Watt
10.2 cm
21.8 cm
15.4 cm
2.5 kg
0 - 95%
Scroll to top
