BT.com
Wishlist
QNAP TVS-EC1080-E3-8G/30TB(10x3TB Seagate E-NAS HDD) 10 bay Deskt
Delivery
Standard Due date unavailable
QNAP TVS-EC1080, featuring the easy-to-use QTS operating system, provides a reliable and scalable NAS solution to fulfill data backup, file synchronization and remote access. The TVS-EC1080 is 10GbE-ready, delivers exceptional performance, and supports cross-platform file sharing, comprehensive backup solutions, iSCSI and virtualization applications, and many practical business functions, making it the ideal choice for SMBs to secure important business data. It also includes abundant multimedia applications backed by its powerful hardware specifications.
QNAP TVS-EC1080 Turbo NAS - NAS server - 30 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
30 TB
10 (installed) / 10 (max)
32.7 cm x 32.12 cm x 21.75 cm
1 x Intel Xeon E3-1200 v3 series E3-1245V3 3.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
10 x 3 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
8 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X or later, Microsoft Windows Server 2003 or later
NAS server
Host Connectivity
Gigabit Ethernet
30 TB
32.7 cm
32.12 cm
21.75 cm
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 32 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap - 3.5"
10 x 3 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Buffer Size
64 MB
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, ALERT notification, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, 256-bit encryption, firmware upgradable, proxy server, MySQL server, web server, backup server, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
IEEE 802.3ad (LACP), IEEE 802.1x, UPnP
Expansion Bays
10 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCI Express 3.0 x8
6 x USB 2.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x HDMI output , 2 x eSATA
4 x network cable
Audible alarm, lockable, K-lock security slot, built-in 2 cooling fans
FIPS 140-2
Internal power supply
Power Provided
350 Watt
QNAP QTS 4.1
Software Included
Drivers & Utilities
5 - 95% (non-condensing)
Scroll to top
