BT.com
Wishlist
QNAP TVS-EC1080-E3-16G 60TB (10 x 6TB WD RED PRO HDDs) 10 Bay Desktop NAS
Delivery
Standard Due date unavailable
QNAP TVS-EC1080, featuring the easy-to-use QTS operating system, provides a reliable and scalable NAS solution to fulfill data backup, file synchronization and remote access. The TVS-EC1080 is 10GbE-ready, delivers exceptional performance, and supports cross-platform file sharing, comprehensive backup solutions, iSCSI and virtualization applications, and many practical business functions, making it the ideal choice for SMBs to secure important business data. It also includes abundant multimedia applications backed by its powerful hardware specifications.
QNAP TVS-EC1080 Turbo NAS - NAS server - 60 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
60 TB
10 (installed) / 10 (max)
32.7 cm x 32.12 cm x 21.75 cm
12.52 kg
1 x Intel Xeon E3-1200 v3 series 3.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
10 x 6 TB
10Mb LAN, 100Mb LAN, GigE
RAM
16 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
60 TB
32.7 cm
32.12 cm
21.75 cm
12.52 kg
Built-in Devices
Status LCD
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 32 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap
10 x 6 TB
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, ALERT notification, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, RADIUS support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
IEEE 802.3ad (LACP), IEEE 802.1x, UPnP
Expansion Bays
10 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , X DIMM 240-pin
2 x eSATA , 6 x USB 2.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
4 x network cable
Lockable, built-in 2 cooling fans
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
350 Watt
QNAP QTS 4.1
Software Included
Drivers & Utilities
5 - 95% (non-condensing)
Sound Emission
54.57 dBA
Scroll to top
