BT.com
Wishlist
QNAP TVS-863+-16G/32TB-Red Pro 8 Bay Desktop NAS
Delivery
Standard Due date unavailable
Adorned with a box in gold color, the sophisticated TVS-863+, featuring the easy-to-use QTS operating system, is a powerful, reliable, secure and scalable NAS solution designed for mission-critical and intensive business applications and to meet fast growing data storage needs. The TVS-863+ supports 10GbE via optional PCI-E network expansion and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
What's in the box
  • QNAP TVS-863+ Turbo NAS
  • 2 x network cable
QNAP TVS-863+ Turbo NAS - NAS server - 32 TB
NAS server
Host Connectivity
10 Gigabit Ethernet
Total Storage Capacity
32 TB
8 (installed) / 8 (max)
29.82 cm x 23.54 cm x 18.52 cm
1 x AMD 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
8 x 4 TB
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
16 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003
NAS server
Host Connectivity
10 Gigabit Ethernet
32 TB
29.82 cm
23.54 cm
18.52 cm
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
1 x AMD 2.4 GHz
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 16 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap
8 x 4 TB
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
256-bit AES
UPnP
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express
2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x HDMI output , 1 x Ethernet 10Gb - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, lockable
Security Slot Type
Kensington security slot
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Scroll to top
