BT.com
Wishlist
QNAP TVS-471U-RP-I3-4G/12TB-RED PRO Rackmount NAS
Delivery
Standard Due date unavailable
The QNAP TVS-471U-RP, featuring the easy-to-use QTS operating system, provides a reliable and scalable NAS solution to fulfill data backup, file synchronization and remote access. The TVS-471U-RP is 10GbE-ready, delivers exceptional performance, and supports cross-platform file sharing, comprehensive backup solutions, iSCSI and virtualization applications, and many practical business functions, making it the ideal choice for SMBs to secure important business data. It also includes abundant multimedia applications backed by its powerful hardware specifications.
QNAP TVS-471U-RP - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
43.9 cm x 49.9 cm x 4.4 cm
7.63 kg
1 x Intel Core i3 4150 3.5 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 3 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
4 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
12 TB
43.9 cm
49.9 cm
4.4 cm
7.63 kg
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
4 x 3 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Buffer Size
64 MB
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
256-bit AES
UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 2.0 - Type A , 4 x USB 3.0 - Type A , 1 x HDMI output
4 x network cable
Audible alarm, lockable, K-lock security slot, built-in 2 cooling fans
FIPS 140-2
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
250 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Scroll to top
