BT.com
Wishlist
QNAP TVS-1282T-i5-16G 12 Bay Enclosure
Delivery
Standard Due date unavailable
The TVS-1282T features enhanced hardware by adopting powerful processors and was designed around the concept of tiered storage, application-based partitioning and network traffic distribution. Providing a Thunderbolt DAS/NAS/iSCSI SAN triple solution, the TVS-1282T delivers the power of Thunderbolt 2 to double the speed potential to 20 Gbps, supports smooth 4K 60 fps video transfer and display, and is a perfect match for Thunderbolt-equipped Mac users for 4K workflows, file storage and high-speed sharing. Incorporating reliability, security and rich applications, the TVS-1282T delivers the highest transfer rates ever as storage with persistent throughput, and provides a complete business-ready storage solution.
What's in the box
  • QNAP TVS-1282T
  • 6 x network cable
  • Mounting kit, remote control
QNAP TVS-1282T - NAS server - 0 GB
NAS server
Host Connectivity
10 Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 12 (max)
36.99 cm x 31.98 cm x 23.46 cm
11.55 kg
Danish, Hungarian, Czech, Thai, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Romanian, Japanese, Korean
1 x Intel Core i5 6500 3.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
16 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
10 Gigabit Ethernet
0 GB
36.99 cm
31.98 cm
23.46 cm
11.55 kg
Built-in Devices
Stereo speakers, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 32 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, Access Control List (ACL) support, DHCP server, SMS alert, reset button, IPv4 support, DHCP client, 4K resolution support, cloud backup, Real-time Remote Replication (RTRR)
Encryption Algorithm
SSL, 128-bit AES, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5"
Expansion Slots
2 x PCI Express 3.0 x4 , 1 x PCI Express 3.0 x8 , 2 (total) / 2 (free) x M.2
4 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb , 5 x USB 3.0 - Type A , 3 x HDMI output - Type A , 2 x Thunderbolt 2 , 1 x audio out - mini-jack , 2 x audio in - 6.3mm jack
6 x network cable
Built-in 3 cooling fans
FIPS 140-2
Internal power supply
QNAP QTS 4.2
5 - 95% (non-condensing)
Sound Emission
21.6 dB
Scroll to top
