BT.com
Wishlist
QNAP TVS-1271U-RP-i5-16G 12 Bay Rackmount NAS
QNAP TVS-1271U-RP-i5-16G 12 Bay...
£2,397.37
£2,397.37
Add to wishlist
Delivery
Standard 1-3 working days
The QNAP TVS-1271U-RP, featuring the easy-to-use QTS operating system, provides a reliable and scalable NAS solution to fulfill data backup, file synchronization and remote access. The TVS-1271U-RP is 10GbE-ready, delivers exceptional performance, and supports cross-platform file sharing, comprehensive backup solutions, iSCSI and virtualization applications, and many practical business functions, making it the ideal choice for SMBs to secure important business data.
QNAP TVS-1271U-RP - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
Max Supported Capacity
96 TB
0 (installed) / 12 (max)
48.2 cm x 53.4 cm x 8.9 cm
16.14 kg
1 x Intel Core i5 4590S 3 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, GigE
RAM
16 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 GB
96 TB
48.2 cm
53.4 cm
8.9 cm
16.14 kg
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 32 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, SNMP support
Encryption Algorithm
256-bit AES
UPnP
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 x PCI Express 3.0 x4 , 1 x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 2.0 - Type A , 4 x USB 3.0 - Type A , 1 x HDMI output
4 x network cable
Audible alarm, lockable, built-in 3 cooling fans
FIPS 140-2
Internal power supply
Power Provided
500 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Other bundles
£2,397.37
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.19
£2,400.56
Scroll to top
