BT.com
Wishlist
QNAP TS-853U-RP 8 Bay Rackmount NAS Enclosure
Delivery
Standard Due date unavailable
The TS-853U-RP, featuring the easy-to-use QTS operating system, is a powerful, reliable, secure and scalable NAS solution designed for mission-intensive business applications and to meet fast growing data storage needs. The TS-853U-RP supports SATA 6Gb/s drives and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
QNAP TS-853U-RP - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
0 (installed) / 8 (max)
48.2 cm x 53.4 cm x 8.9 cm
11.02 kg
1 x Intel Celeron 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, GigE
RAM
4 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.1
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 GB
48.2 cm
53.4 cm
8.9 cm
11.02 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, RADIUS support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, DLNA Media Server, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
SSL, 256-bit AES
IEEE 802.3ad (LACP), IEEE 802.1x, UPnP
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 1 x HDMI output , 1 x management
2 x network cable
Audible alarm, wake on LAN, built-in 2 cooling fans
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
250 Watt
QNAP QTS 4.1
0 - 95%
Scroll to top
