BT.com
Wishlist
QNAP TS-531P-2G/10TB-RED 5 Bay Desktop NAS
Delivery
Standard Due date unavailable
The 5-bay TS-531P is a powerful quad-core network storage system, providing the potential for 10GbE expandability at a budget price to maximize ROI, and doubles the encrypted file transfer performance with a strong hardware-accelerated encryption engine. The energy-efficient ARM Cortex-A15 processor provides ultra low power consumption for daily business operations to save cost in the long run. Powered by the QTS operating system, the TS-531P provides versatile all-in-one server functionalities as well as unique features including Container Station, which allows you to run multiple isolated Linux systems and containerized applications on the same device. The TS-531P is a cost-effective storage solution designed for growing businesses looking for backup, restoration, private cloud, storage for virtualization, and to future-proof their IT infrastructure for 10GbE networks.
QNAP TS-531P - NAS server - 10 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
10 TB
5 (installed) / 5 (max)
21.06 cm x 25.34 cm x 18.5 cm
1 x Annapurna Labs Cortex-A15 1.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
5 x 2 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Gigabit Ethernet
10 TB
21.06 cm
25.34 cm
18.5 cm
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 16 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - 3.5"
5 x 2 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, DHCP, Bonjour
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, LDAP support, wake on LAN (WOL), Syslog support, print server, IPv6 support, proxy server, backup server, Trivial File Transfer Protocol (TFTP) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, UPnP Media Server, IPv4 support, surveillance station, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, Apple AirPlay
Encryption Algorithm
SSL, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express 2.0 x4
4 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
FIPS 140-2
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.2
5 - 95% (non-condensing)
Scroll to top
