BT.com
Wishlist
QNAP TS-451 12TB (4x3TB WD RED) 4 Bay NAS
Delivery
Standard Due date unavailable
The TS-451 is consumer-grade NAS that supports Intel VT-x and virtual machine applications. Just download the Virtualization Station App from App Center, and you can install & operate multiple operating systems with Windows, Linux, and UNIX. The virtual machines can be used in a variety of different ways to boost the functionality of your Turbo NAS. Virtualization technology is normally solely used in enterprise environments, but with the growing needs of a digital household, virtualization is slowly becoming part of your everyday applications. Many households have printers, and when users want to print out the photos stored on their Turbo NAS, but have a printer with Windows only drivers, they would need to startup their PC just for this simple task.
QNAP TS-451 - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
18 cm x 23.5 cm x 17.7 cm
1 x Intel Celeron 2.41 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 3 TB
10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X or later, Microsoft Windows Server 2003 or later
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
18 cm
23.5 cm
17.7 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap
4 x 3 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, DNS, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, proxy server, web server, backup server, download client, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, teaming support, DLNA Media Server, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x HDMI output
2 x network cable
Audible alarm, K-lock security slot, built-in cooling fan
External power adapter
AC 120/230 V
Power Provided
90 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Scroll to top
