BT.com
Wishlist
QNAP TS-431 4TB-Red 4 Bay NAS
Delivery
Standard Due date unavailable
The TS-431 is a powerful yet easy-to-use network storage center for backup, synchronization, remote access, and home entertainment. With the Notes Station, you can easily create digital notes on your private cloud and share with friends and colleagues at no extra cost. Powered by an advanced ARM Cortex A9 dual-core processor, the TS-431 delivers incredible performance as a home NAS with three USB 3.0, one eSATA, and dual LAN ports. The TS-431 can enhance your digital lifestyle.
QNAP TS-431 - NAS server - 4 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
4 TB
4 (installed) / 4 (max)
18 cm x 23.5 cm x 17.7 cm
1 x ARM Cortex-A9 1.2 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 1 TB
10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
AC 120/230 V
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X or later, Microsoft Windows Server 2003 or later, Microsoft Windows 7 or later
NAS server
Host Connectivity
Gigabit Ethernet
4 TB
18 cm
23.5 cm
17.7 cm
Built-in Devices
Led panel, print server
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap
4 x 1 TB
Spindle Speed
7200 rpm
Network / Transport Protocol
TCP/IP, PPTP, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, 256-bit encryption, proxy server, web server, backup server, download client, file sharing, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, eMule client, NTP server, DHCP client, VPN Server, SNMP support, Apple AirPlay
Encryption Algorithm
SSL, TLS, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x eSATA
1 x network cable
Security lock slot (cable lock sold separately), audible alarm, built-in cooling fan, AirPlay, scheduled power on/off
VCCI, C-Tick, BSMI, FCC
External power adapter
AC 120/230 V
33.75 Watt
Power Provided
90 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Scroll to top
