BT.com
Wishlist
QNAP TS-251C/16TB-RED 2 Bay NAS
Delivery
Standard Due date unavailable
The TS-251C is a high-performance storage solution with incredible affordability for home/SOHO users. The TS-251C performs as an easy-to-use yet powerful NAS for data backup, file synchronization, remote access, home entertainment, and is ideal for users to build a personal cloud to access their data easily.
QNAP TS-251C - personal cloud storage device - 16 TB
Personal cloud storage device
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
16 TB
2 (installed) / 2 (max)
8.5 cm x 21.84 cm x 16.65 cm
1 x Intel Celeron 2.41 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1
Hard Drive
2 x 8 TB
10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows 7 / Windows 8 (64 bits)
Host Connectivity
Gigabit Ethernet
16 TB
8.5 cm
21.84 cm
16.65 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB (installed) / 1 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1
Hard Drive
HDD - 3.5"
2 x 8 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, video server, firmware upgradable, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay
Encryption Algorithm
FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 0 (free) x internal - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x HDMI output
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
External power adapter
AC 120/230 V
15.71 Watt
Power Provided
60 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Scroll to top
