BT.com
Wishlist
QNAP TS-231+/2TB-RED 2 Bay NAS
Delivery
Standard Due date unavailable
The TS-231+ is a powerful yet easy-to-use network storage center for backup, synchronization, remote access, and home entertainment. With the Notes Station, you can easily create digital notes on a secure private cloud and share with colleagues and friends at no extra cost. Powered by an advanced ARM dual-core processor, the TS-231+ delivers outstanding multitasking performance as a SOHO NAS featuring three USB 3.0 and dual LAN ports. See how TS-231+ can enhance your working productivity & digital life.
QNAP TS-231+ - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
0 (installed) / 2 (max)
10.2 cm x 22.5 cm x 16.85 cm
1.28 kg
1 x ARM Cortex-A15 1.4 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 1 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows 2003, Microsoft Windows Vista / XP, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
10.2 cm
22.5 cm
16.85 cm
1.28 kg
Built-in Devices
Print server
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 1 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Apple File Protocol (AFP), HTTP, Web-based Distributed Authoring and Versioning (WebDAV)
LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, backup server, Access Control List (ACL) support, iTunes server, DHCP server, SMS alert, IPv4 support, surveillance station, DLNA Media Server, DHCP client, VPN Server, Apple AirPlay
Encryption Algorithm
SSL, FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, AirPlay, scheduled power on/off
VCCI, C-Tick, BSMI, FCC
External power adapter
AC 120/230 V
16.01 Watt
Power Provided
60 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Scroll to top
