BT.com
Wishlist
QNAP TS-131/8TB-RED 1 Bay NAS
Delivery
Standard Due date unavailable
The TS-131 is a powerful yet easy-to-use network storage center for backup, synchronization, remote access, and home entertainment. With the Notes Station, you can easily create digital notes on your private cloud and share with friends and colleagues at no extra cost. Powered by an advanced ARM Cortex A9 dual-core processor, the TS-131 delivers incredible performance as a home NAS with three USB 3.0, one eSATA. See how TS-131 can enhance your digital lifestyle.
QNAP TS-131 - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
1 (installed) / 1 (max)
7.3 cm x 22.5 cm x 16.85 cm
1 x ARM Cortex-A9 1.2 GHz (Dual-Core)
Storage Controller
SATA SATA 6Gb/s / eSATA
Hard Drive
1 x 8 TB
10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
AC 120/230 V
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows 7
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
7.3 cm
22.5 cm
16.85 cm
Built-in Devices
Print server
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB
Flash Memory Installed
512 MB
Storage Controller
SATA
Interface Type
SATA 6Gb/s / eSATA
Hard Drive
HDD - hot-swap
1 x 8 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Apple File Protocol (AFP), HTTP, Web-based Distributed Authoring and Versioning (WebDAV)
Wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, proxy server, web server, backup server, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, IPv4 support, surveillance station, DLNA Media Server, eMule client, NTP server, DHCP client, VPN Server, SNMP support, Apple AirPlay
Encryption Algorithm
SSL, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
1 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x eSATA
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, AirPlay, scheduled power on/off
VCCI, C-Tick, BSMI, FCC
External power adapter
AC 120/230 V
13.31 Watt
Power Provided
36 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
Scroll to top
