BT.com
Wishlist
QNAP TES-3085U-D1548-32G
Delivery
Standard Due date unavailable
The powerful enterprise-class TES-3085U is open for two operating systems - either the FreeBSD-based QES or Linux-based QTS. While QES supports ZFS for the utmost reliability and allows near-limitless snapshots, block-level data deduplication and real-time data compression, QTS features Qtier Technology, SSD cache, and an abundance of value-added apps to realize storage efficiency and diverse usage applications. The TES-3085U gives the flexibility to choose from two operating systems, enabling businesses to deploy proper operating systems on multiple TES-3085U based on their needs and goals in different stages. The TES-3085U is especially useful for providing a speedy all-flash storage solution that offers up to 24 disk bays and 6 dedicated SDDs bays for caching.
What's in the box
  • QNAP TES-3085U
  • 4 x network cable
QNAP TES-3085U - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
0 (installed) / 30 (max)
43.9 cm x 48.45 cm x 8.8 cm
13.98 kg
1 x Intel Xeon D-1548 2 GHz (8-core)
Storage Controller
RAID SATA 6Gb/s / SAS 12Gb/s - RAID 0, 1, 5, 6, 10, 50, JBOD, 60
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
32 GB
Power Redundancy
Storage Operating System
QNAP QES 1.1 / QTS 4.2
UNIX, Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Windows 10 (32/64 bits)
5 years warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
0 GB
43.9 cm
48.45 cm
8.8 cm
13.98 kg
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
8-core
RAM
32 GB (installed) / 128 GB (supported) - DDR4
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Load balancing, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, High Availability, 256-bit encryption, firmware upgradable, proxy server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, Network Access Protection (NAP), reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, LACP support, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR)
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
UPnP
Expansion Bays
24 (total) / 24 (free) x hot-swap - 2.5" / 3.5" , 6 (total) / 6 (free) - 2.5"
Expansion Slots
4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 2.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0
4 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb - SFP+
4 x network cable
Wake on LAN, AirPlay, built-in 4 cooling fans, hot-swappable fans
FIPS 140-2
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
450 Watt
Limited warranty - 5 years
5 - 95% (non-condensing)
Scroll to top
