BT.com
Wishlist
QNAP REXP-1000 PRO/30TB(10x3TB Seagate E-NAS HDD) 10 bay Desktop
Delivery
Standard Due date unavailable
The QNAP REXP-1000 Pro expansion enclosure is designed for expanding the storage space on the Turbo NAS by connecting multiple expansion enclosures via high-speed mini SAS cables. This is especially useful for large data applications, such as video surveillance, data archiving, and TV broadcast storage.
QNAP REXP-1000 Pro - storage enclosure
Storage enclosure
Total Array Capacity
30 TB
SAS 6Gb/s
10 (installed) / 10 (max)
Supported Drives
SATA-600 / SAS-2
Built-in Devices
Led panel
Storage Controller
(SATA 6Gb/s / SAS 6Gb/s)
Hard Drive
10 x 3 TB HDD SATA 6Gb/s - hot-swap
AC 120/230 V - 47 - 63 Hz
32.7 cm x 32.12 cm x 21.75 cm
9.24 kg
Storage enclosure
Chassis
Built-in Devices
Led panel
10
Supported Devices / Modules Qty
10
Supported Drives
SATA-600 / SAS-2
Storage
30 TB
HDD Array External Interface
SAS 6Gb/s
Storage Controller
Interface Type
Data Transfer Rate
600 MBps
Max Storage Devices Qty
10
Hard Drive
HDD - hot-swap
10 x 3 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
10 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x SAS 6Gb/s (input) , 1 x SAS 6Gb/s (output) , 1 x serial (management) - 9 pin D-Sub (DB-9)
Security lock slot (cable lock sold separately), built-in 2 cooling fans
1 x SAS cable - 50 cm
Software Included
Drivers & Utilities
Internal power supply
Power Provided
350 Watt
32.7 cm
32.12 cm
21.75 cm
9.24 kg
5 - 95% (non-condensing)
Sound Emission
34.6 dB
Scroll to top
