BT.com
Wishlist
QNAP IS-453S-2G/32TB-RED 4 Bay NAS
Delivery
Standard Due date unavailable
The IS-453S is a robust all-in-one industrial NAS designed for reliable operations in harsh environments. Featuring a fanless design with high vibration and impact resistance, the IS-453S is ideal for factories, warehouses, and transportation with operating temperatures between -40°C and 50°C (-40°F to 122°F). The IS-453S delivers high performance with persistent throughput and provides a comprehensive storage solution.
QNAP IS-453S - NAS server - 32 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
32 TB
4 (installed) / 4 (max)
18 cm x 24.7 cm x 5.9 cm
1 x Intel Atom 1.91 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 8 TB
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Gigabit Ethernet
32 TB
18 cm
24.7 cm
5.9 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap
4 x 8 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, DDNS
Remote Management Protocol
SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
VPN support, trunking, print server, IPv6 support, DFS support, proxy server, iTunes server, Digital Optical Monitoring (DOM) support, Jumbo Frames support, DHCP server, Samba support, SMS alert, UPnP Media Server, DLNA Media Server, DHCP client, cloud backup, Wi-Fi USB dongle support
Encryption Algorithm
SSL, TLS, 256-bit AES
UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x HDMI output
2 x network cable
Fanless, rugged
FCC Class B certified, FIPS 140-2, MIL-STD 810G 514.6
External power adapter
AC 120/230 V
10.04 Watt
Power Provided
90 Watt
QNAP QTS 4.2
-40 °C
50 °C
5 - 95% (non-condensing)
Scroll to top
