BT.com
Wishlist
QLogic Single-port 8Gb Fibre Channel Host Bus Adapter
QLogic Single-port 8Gb Fibre...
£520.53
15 in stock
£520.53
Add to wishlist
Delivery
Standard 1-3 working days
The QLogic 8Gb FC Single-port HBA for IBM System x is PCI Express 2.0 x8 8Gb Fiber Channel adapter with SFP+ LC-style connectors. The adapter connects to SFP+ Multimode Fiber SR optical modules. This adapter supports 8 Gbps per port maximum bidirectional throughput for high-bandwidth storage (SAN). The PCI Express low profile form factor adapter can be used in either a standard PCI Express slot or a low profile PCI Express slot.
QLogic 8Gb FC Single-port HBA for IBM System x - host bus adapter
Host bus adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
PCI Specification Revision
PCIe 1.0a, PCIe 1.0
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
8Gb Fibre Channel
2.5 cm x 16.8 cm x 6.5 cm
113 g
8Gb Fibre Channel
Data Transfer Rate
8.5 Gbps
RAM
1 MB
1 year warranty
System Storage DS3400; System x3100 M4; x3100 M5; x3200 M2; x3250 M2; x3250 M3; x3250 M4; x3250 M6; x3300 M4; x3350; x3400; x3450; x3500; x3550; x3550 M2; x3620 M3; x3630 M3; x3630 M4; x3650; x3650 M2; x3650 M4 HD; x3655; x3755; x3850 M2; x3950 M2; x3950 X5
Host bus adapter
Plug-in card
PCI Express x4
PCIe 1.0a, PCIe 1.0
Bus Voltage
Ports
8Gb Fibre Channel
Wired
8Gb Fibre Channel
Data Transfer Rate
8.5 Gbps
Auto-negotiation
Processor / Memory
RAM
1 MB
Flash Memory
1 MB
1 x 8Gb Fibre Channel
Compatible Slots
1 x PCI Express
UL, TUV, VCCI Class B ITE, BSMI CNS 13438 Class B, cUL, DHHS, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, UL 60950, ICES-003 Class B, AS/NZ 3548 Class B, FCC Part 15 B, MIC, CSA C22.2, EN 60950-1, EN 60825
2.5 cm
16.8 cm
6.5 cm
113 g
Limited warranty - 1 year - on-site
45 °C
5 - 95%
IBM System Storage DS3400 Model 41E, DS3400 Model 41X, DS3400 Model 42E, DS3400 Model 42T, DS3400 Model 42X , Lenovo System x3100 M4 2582 , Lenovo System x3100 M5 , Lenovo System x3200 M2 , Lenovo System x3250 M2 , Lenovo System x3250 M3 4252 , Lenovo System x3250 M4 , Lenovo System x3250 M6 , Lenovo System x3300 M4 , Lenovo System x3350 , Lenovo System x3400 , Lenovo System x3450 , Lenovo System x3500 , Lenovo System x3550 , Lenovo System x3550 M2 , Lenovo System x3620 M3 , Lenovo System x3630 M3 7377 , Lenovo System x3630 M4 , Lenovo System x3650 , Lenovo System x3650 M2 , Lenovo System x3650 M4 HD , Lenovo System x3655 , Lenovo System x3755 , Lenovo System x3850 M2 , Lenovo System x3950 M2 , Lenovo System x3950 X5
Accessories
£12.37
£13.98
£18.15
£23.08
Scroll to top
