BT.com
Wishlist
PSA Parts PSA AC Adaptor 40w
£19.28
More than 50 in stock
£19.28
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
2-Power - power adapter
Power adapter - external
140 g
Input Voltage
AC 110-240 V
Output Voltage
19 V
8.8 cm x 3.5 cm x 2.6 cm
1 year warranty
Compaq Mini 110, 700, 701, 702, 705, 730, 731, 732, 733, 735; HP Mini 100, 1000, 1001, 1002, 1003, 1004, 1010, 1018, 1019, 1020, 1030, 1033, 1035, 1050, 1090, 1097, 1098, 1099, 110, 1101, 1109, 1110, 1115, 1116, 1120, 1128, 1133, 1135, 1137, 1140, 1141, 1150, 1153, 1160, 1180, 1190, 1198, 1199
Input Voltage
AC 110-240 V
Output Voltage
19 V
Limited warranty - 1 year
8.8 cm
3.5 cm
2.6 cm
140 g
Compaq Mini 110c-1000SN, 110c-1010EA, 110c-1010SB, 110c-1033EZ, 110c-1048NR, 110c-1050SF, 110c-1100DX, 110c-1100SB, 110c-1100SO, 110c-1101SO, 110c-1103SO, 110c-1110EC, 110c-1110EH, 110c-1110EM, 110c-1110ES, 110c-1110EZ, 110c-1110SA, 110c-1110SD, 110C-1110SG, 110c-1110SH, 110c-1110SP, 110c-1115EG, 110c-1115SS, 110c-1120SA, 110c-1120SO, 110c-1120SS, 110c-1130ED, 110c-1130EF, 110c-1130SA, 110c-1130SF, 110c-1130SS, 110c-1133EZ, 110c-1150EB, 110c-1150SS, 700EA , HP Mini 1000, 100e, 1018TU, 1019TU, 1020TU, 1097ei, 1098ei, 1099ea, 1099ed, 1099ef, 1099eg, 1099eh, 1099ek, 1099el, 1099en, 1099ep, 1099ES, 1099ew, 110-1010SA, 110-1012NR, 110-1016LA, 110-1020BR, 110-1030CA, 110-1033CL, 110-1034NR, 110-1037NR, 110-1040LA, 110-1040TU, 110-1046NR, 110-1050BR, 110-1050LA, 110-1081TU, 110-1090LA, 110-1100SL, 110-1102EW, 110-1105SL, 110-1109NR, 110-1110EL, 110-1112NR, 110-1113NR, 110-1115CA, 110-1115NR, 110-1115SA, 110-1116CA, 110-1116NR, 110-1117CA, 110-1125BR, 110-1125LA, 110-1125NR, 110-1125SA, 110-1126LA, 110-1126NR, 110-1127NR, 110-1129NR, 110-1130LA, 110-1130SA, 110-1130SL, 110-1131DX, 110-1131LA, 110-1134CL, 110-1134TU, 110-1135NR, 110-1135TU, 110-1140EL, 110-1140EP, 110-1140LA, 110-1140SS, 110-1144EZ, 110-1145SS, 110-1146SS, 110-1147SS, 110-1150BR, 110-1150ED, 110-1150EG, 110-1150LA, 110-1150NR, 110-1150SA, 110-1150sf, 110-1150SS, 110-1155SS, 110-1156TU, 110-1160EP, 110-1160sa, 110-1160SB, 110-1160SL, 110-1165EP, 110-1165SB, 110-1170ES, 110-1170sf, 110-1180SF, 110-1190BR, 110-1190LA, 110-1190sf, 110-1191eo, 110-1192eo, 110-1193EO, 110-1197TU, 110-1199EA, 110-1199EC, 110-1199ed, 110-1199EG, 110-1199EM, 110-1199eo, 110-1199ES, 110-1199EZ, 110-3001SG, 110-3001sl, 110-3002SG, 110-3002sl, 110-3013EZ, 110c-1100sw, 110C-1110SH, 110C-1111SL, 110c-1125eg, 110C-1130SF, 110C-1150SS, 110c-1190eo, 110c-1191eo, 110c-1199eo, 110se-1199ef, 1120BR, 1133CA, 1135CA, 1140NR, 1141NR, 1150BR, 1190BR, 1198EO, 1199eb, 1199ec, 1199EO, 1199ep
Scroll to top
