BT.com
Wishlist
PSA Parts Main Battery Pack 10.8v 5200mAh 56Wh
PSA Parts Main Battery Pack 10.8v...
£58.69
45 in stock
£58.69
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
2-Power Main Battery Pack - laptop battery - Li-Ion - 5200 mAh
Laptop battery
308 g
Lithium Ion 5200 mAh
Batteries Qty
1
8 cm x 20.5 cm x 2.1 cm
Compaq Presario CQ40, CQ41, CQ45, CQ50, CQ60, CQ61, CQ70, CQ71; HP G50, G60, G61, G70, G71, HDX X16-1000, HDX X16-1001, HDX X16-1005, HDX X16-1010, HDX X16-1025, HDX X16-1040, HDX X16-1044, HDX X16-1056, HDX X16-1060, HDX X16-1155, HDX X16-1160, HDX X16-1275, HDX X16-1299; Pavilion dv4, dv5, DV6
Laptop battery
Quantity
1
Lithium Ion
Voltage Provided
10.8 V
5200 mAh
8 cm
20.5 cm
2.1 cm
308 g
Compaq Presario CQ45-700LA, CQ45-707TU, CQ45-800LA, CQ45-802TU , HP G61-429WM, G71-333CA , HP Pavilion dv4-1414la, dv4-1416la, dv4-1423la, dv4-1520la, dv4-1523la, dv4-1622la, dv4-1624la, dv4-2014la, dv4-2111la, dv4-2116la, dv4-2154ca, dv4-2162nr, dv4-2167sb, dv4-2169nr, dv4-2170us, dv5-1100, dv5-1147la, dv5-1209eo, dv5-1241la, dv5-2032la, dv5-2035dx, dv5-2040ca, dv5-2043la, dv5-2045dx, dv5-2045la, dv5-2046la, dv5-2048la, dv5-2070us, dv5-2072nr, dv5-2073nr, dv6-1110eo, dv6-1120ep, dv6-1131sa, DV6-1149WM, dv6-1160ep, dv6-1170ep, dv6-1215sg, dv6-1240ef, dv6-1243cl, dv6-1247cl, dv6-1275la, dv6-1308el, dv6-1310sl, dv6-1315ec, dv6-1317ss, dv6-1320en, dv6-1320eo, dv6-1320ep, dv6-1329tx, dv6-1330eb, dv6-1340ef, dv6-1360ss, dv6-1388la, dv6-1410ez, dv6-1410ss, dv6-1410sw, dv6-1420sw, dv6-1425ei, dv6-1430ey, dv6-1430sw, dv6-2006tx, dv6-2012ax, dv6-2021el, dv6-2025sf, dv6-2040sa, dv6-2043ca, dv6-2043us, dv6-2057cl, dv6-2064ca, dv6-2100es, dv6-2100ey, dv6-2105eo, dv6-2105es, dv6-2108ea, dv6-2108eo, dv6-2108sa, dv6-2109eo, dv6-2110AX, dv6-2110ef, dv6-2110el, dv6-2110eo, dv6-2110ss, dv6-2110sw, dv6-2113tx, dv6-2114ef, dv6-2115eg, dv6-2115es, dv6-2115ew, dv6-2116sg, dv6-2117ax, dv6-2117eg, dv6-2117sa, dv6-2118el, dv6-2120ey, dv6-2120so, dv6-2121eo, dv6-2122eo, dv6-2122ez, dv6-2123el, dv6-2123eo, dv6-2123sf, dv6-2124el, dv6-2124eo, dv6-2125ew, dv6-2126el, dv6-2126eo, dv6-2126ew, dv6-2127el, dv6-2130ca, dv6-2130el, dv6-2130ew, dv6-2130ez, dv6-2131so, dv6-2132eo, dv6-2133eg, dv6-2133sf, dv6-2135ew, dv6-2136el, dv6-2136eo, dv6-2137sl, dv6-2138eo, dv6-2140eb, dv6-2140eh, dv6-2140el, dv6-2141sl, dv6-2142sl, dv6-2145ew, dv6-2145sf, dv6-2147es, dv6-2150ca, dv6-2150el, dv6-2150es, dv6-2150ey, dv6-2150sb, dv6-2151cl, dv6-2153el, dv6-2155el, dv6-2155ew, dv6-2157el, dv6-2157wm, dv6-2158so, dv6-2160eg, dv6-2160el, dv6-2160ez, dv6-2166sb, dv6-2168es, dv6-2168sl, dv6-2171nr, dv6-2171sl, dv6-2175ss, dv6-2177la, dv6-2180ey, dv6-2186es, dv6-2191sl
Scroll to top
