BT.com
Wishlist
PSA Parts AC Adapter 19.5V 3.34A 65W (4.5mmx3.0mm) includes Power Cable
PSA Parts AC Adapter 19.5V 3.34A...
£34.14
10 in stock
£34.14
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
PSA AC Adapter - power adapter - 65 Watt
Power adapter - external
Input Voltage
AC 110-240 V
Output Voltage
19.5 V
Power Capacity
65 Watt
Output connectors
1 x power DC jack 4.5 mm (ID: 3.0 mm)
1 year warranty
Dell Chromebook 13 7310; Inspiron 11 3138, 11 3147, 11 3148, 13 7347, 13 7348, 3452, 5555, 5559, 5758; OptiPlex 3020 (micro), 9020 (micro); Vostro 3558, 3559, 5459
Input Voltage
AC 110-240 V
Output Voltage
19.5 V
Max Electric Current
3.34 A
Power Capacity
65 Watt
Limited warranty - 1 year
Dell Chromebook 13 7310 , Dell Inspiron 11 3138, 11 3147, 11 3148, 13 7347, 13 7348, 3452, 5555, 5559, 5758 , Dell OptiPlex 3020 (micro), 9020 (micro) , Dell Vostro 3558, 3559, 5459
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: BGY3 035062
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£10.81
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
