Click to visit BT.com
BT.com
Wishlist
Proper Medium Tripod
Quicklinx: 8PLZWS00
Mfr#: PTS20
Offer excellent support for your CSC, DSLR or camcorder with this medium sized tripod. Use the spirit level to ensure your tripod legs are evenly distributed; adjust the pan by the handle so that your camera is at a comfortable operating length and position, and within minutes you will have a great selection of photographs. The tripod comes complete with a carry case so it is easily transported.
- Universal camera/ camcorder link attachment
- 3 section channel leg design
- 3 way pan & tilt head
- Quick release plate included
- Spirit level
- Height adjustable geared central column
- Carrying handle and hook
- Aluminium braced legs with lock
- Adjustable rubber feet
- Carry case included
- Initial Height: 540mm
- Extended height: 1440mm
- Leg diameter: 20mm
- Max weight load: 5kg
- Product net weight: 1180g
Proper Medium Studio Tripod - tripod
Tripod
1.18 kg
Tripod Head Type
Pan
Tripod Operating Height
54 cm - 144 cm
Max Supported Weight
5 kg
Tripod
1.18 kg
Material
Aluminium
Tripod
Tripod Legs Sections Qty
3
Quick Release System
Tripod Centre Column Type
Geared
Max Operating Height
144 cm
Min Operating Height
54 cm
5 kg
Foot Type
Rubber feet
Built-in bubble level, accessory hook, carry handle, leg braces
Tripod Head
Tripod Head
Pan
Tripod Head Positioning
3-way
Case
