BT.com
Wishlist
Proper Medium Tripod
Delivery
Standard Due date unavailable
Offer excellent support for your CSC, DSLR or camcorder with this medium sized tripod. Use the spirit level to ensure your tripod legs are evenly distributed; adjust the pan by the handle so that your camera is at a comfortable operating length and position, and within minutes you will have a great selection of photographs. The tripod comes complete with a carry case so it is easily transported.
- Universal camera/ camcorder link attachment
- 3 section channel leg design
- 3 way pan & tilt head
- Quick release plate included
- Spirit level
- Height adjustable geared central column
- Carrying handle and hook
- Aluminium braced legs with lock
- Adjustable rubber feet
- Carry case included
- Initial Height: 540mm
- Extended height: 1440mm
- Leg diameter: 20mm
- Max weight load: 5kg
- Product net weight: 1180g
Proper Medium Studio Tripod - tripod
Tripod
1.18 kg
Tripod Head Type
Pan
Tripod Operating Height
54 cm - 144 cm
Max Supported Weight
5 kg
Tripod
1.18 kg
Material
Aluminium
Tripod
Tripod Legs Sections Qty
3
Quick Release System
Tripod Centre Column Type
Geared
Max Operating Height
144 cm
Min Operating Height
54 cm
5 kg
Foot Type
Rubber feet
Built-in bubble level, accessory hook, carry handle, leg braces
Tripod Head
Tripod Head
Pan
Tripod Head Positioning
3-way
Case
Scroll to top
