BT.com
Wishlist
Proper Classic Swing Arm Wall TV Bracket for TVs 17"-37"
Proper Classic Swing Arm Wall TV...
£16.58
1 in stock
£16.58
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
Proper Classic Swing Arm TV Bracket - wall mount
Wall mount
22 cm 22 cm
Adjustable Depth
10-23 cm
Tilt
Recommended Use
LCD / plasma panel
Recommended Display Size
17"-40"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
30 kg
Material
Steel
22 cm
22 cm
Adjustable Depth
10-23 cm
Material
Steel
AV Furniture
Wall mount
Mounting Components
Wall mount, swing arm
Recommended Use
LCD / plasma panel
17"-40"
Tilt
Max Load Weight
30 kg
Swivel adjustment
Scroll to top
