BT.com
Wishlist
Promethean UST-P1 Mount Upgrade Kit - DLP Projector with ActivBoard Mount
Delivery
Standard 1-3 working days
The Promethean UST-P1 projector is a high performance Ultra-Short throw DLP unit for classroom use with Promethean's range of ActiveBoards and stands.
Promethean UST-P1 - Mount Upgrade Kit - DLP projector - with ActivBoard Mount
DLP projector
Brightness
3000 ANSI lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Ultra short-throw lens
Bulb type
220 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 8000 hour(s) (economic mode)
Video Input
Composite video
300 Watt
37.5 cm x 28.7 cm x 11 cm
3.7 kg
Bundled with
ActivBoard Mount
DLP projector
Bundled with
ActivBoard Mount
Projector
Brightness
3000 ANSI lumens
Brightness (Reduced)
2500 ANSI lumens
Contrast Ratio
3000:1
Throw Ratio
0.35:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
220 Watt
Bulb life cycle
16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support
Lens
Video Input
Analogue video Signal
Composite video
Video Interfaces
VGA, HDMI, composite video
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB , 1 x network - RJ-45 , 1 x serial RS-232
300 Watt
Power Consumption Stand by
0.5 Watt
37.5 cm
28.7 cm
11 cm
3.7 kg
Sound Emission
33 dB
29 dB
Scroll to top
