BT.com
Wishlist
Promethean PRM-35 DLP Short Throw Projector
Delivery
Standard Due date unavailable
The ActivBoard System PRM-35 is the consummate attention grabber with a state-of-the-art short-throw projector. From the audience, eyes can't help but face forward.
Promethean PRM-35 - DLP projector - 3D
DLP projector - High Definition 720p
3D Capable
Silver
Brightness
2500 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.8 million colours
Bulb type
230 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 480i, 1035i, 576i, 575i
230 Watt
30.6 cm x 27.5 cm x 9.7 cm
4.1 kg
DLP projector - HD 720p
3D Capable
Enclosure Colour
Silver
Projector
Brightness
2500 lumens
Brightness (Reduced)
2100 lumens
Contrast Ratio
2000:1
Image Size
127 cm - 279 cm
Projection Distance
0.54 m - 1.22 m
Resolution
WXGA - WXGA (1280 x 800) (native) / 1680 x 1050 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 90 kHz
Bulb type
230 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Japanese, Korean, Kazakh
Closed Caption, 16:9 aspect ratio support, Crestron RoomView, 16:10 aspect ratio support, 4:3 aspect ratio support, Direct Power On, Direct Power Off
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
1 x HDMI , 1 x network - RJ-45 , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Wireless remote control
1 x VGA cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), PIN code
Nominal Voltage
230 Watt
Software Included
Drivers & Utilities, Crestron RoomView Express
30.6 cm
27.5 cm
9.7 cm
4.1 kg
5 °C
35 °C
Sound Emission
36 dB
32 dB
Scroll to top
