BT.com
Wishlist
Promethean ActivBoard 387 Pro - Whiteboard - 186.5 x 117.5 cm - electromagnetic - wired - USB
Delivery
Standard Due date unavailable
Teaching is quite an experience. Learning should be too. The ActivClassroom has always been all-encompassing. Now, it's an all-in-one interactive, collaborative, multimedia experience designed to capture the imagination of any type of learner - from the auditory to the visual to the kinaesthetic and everywhere between. The reason: the ActivBoard 300 Pro Range, a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. With built in dual-User capability and ActivInspire Professional Edition software included, teachers have access to tens of thousands of free lessons and resources at Promethean Planet.
Promethean ActivBoard 387 Pro - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
211 cm x 7.8 cm x 133 cm
27 kg
Movement Detection Technology
Electromagnetic
Built-in stereo speakers, low-glare surface
1 x USB cable - external - 5 m
Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later, Ubuntu 8.04
5 years warranty
211 cm
7.8 cm
133 cm
27 kg
Input Device
Wired
USB
Electromagnetic
Active Area
186.5 cm x 117.5 cm
2 x USB
Wallmount brackets, 4 x ActivPen
UL, FCC
Limited warranty - 5 years
50 °C
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.70
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.20
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.14
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.52
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£37.98
Scroll to top
