BT.com
Wishlist
Promethean AB395Pro UK
£1,891.53
£1,891.53
Add to wishlist
Delivery
Standard Due date unavailable
Teaching is quite an experience. Learning should be too. The ActivClassroom has always been all-encompassing. Now, it's an all-in-one interactive, collaborative, multimedia experience designed to capture the imagination of any type of learner - from the auditory to the visual to the kinaesthetic and everywhere between. The reason: the ActivBoard 300 Pro Range, a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. With built in dual-User capability and ActivInspire Professional Edition software included, teachers have access to tens of thousands of free lessons and resources at Promethean Planet.
Promethean ActivBoard 395 Pro - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
241 cm 133 cm
31 kg
Movement Detection Technology
Electromagnetic
Low-glare surface
1 x USB cable - external - 5 m
Microsoft Windows Vista / XP, Apple MacOS X 10.4.11 or later, Ubuntu 8.04
3 years warranty
241 cm
133 cm
31 kg
Input Device
Wired
USB
Electromagnetic
Active Area
217.2 cm x 117.5 cm
Low-glare surface
1 x USB
Styluses (4 pcs)
UL, FCC
Limited warranty - 3 years
50 °C
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.86
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.56
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.75
£15.85
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.50
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£21.84
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.51
£42.69
Scroll to top
