BT.com
Wishlist
Prestigio RoadRunner 506 2" HD DashCam inc 16Gb SD Card
Prestigio RoadRunner 506 2" HD...
Exclusive
£54.00
Exclusive
New In
Exclusive to BT!
Hurry, only 1 left in stock!
£54.00
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Prestigio RoadRunner 506 is a compact and autonomous technical video solution for your safety on the road in all conditions. It records Full HD video and takes high resolution pictures (up to 12 MP) to show you in detail what is going on around.
VIDEO QUALITY:
Produces high quality videos in Full HD 1080p with pure sound and crystal clear images to see in detail what is going on around.
2.0" DISPLAY:
Playback videos and view photos on bright hi-resolution 2" TFT LCD display with easy to use controls.
MOTION DETECTION:
in this mode, video shooting starts only when detecting a new movement in the frame. Consequently, it allows you to save the memory card for a longer video.
MAGNETIC CRADLE:
Easy to install and remove device without causing any damage. The device is securely fixed into cradle due to high-powered magnets.
Display Size
2.0" | 480x240 px
NT96223
Video I Photo Resolution
1920x1080 25fps | 12 MP
Image Sensor
2 MP CMOS | Samsung 5B3
Lens | Viewing Angle | Zoom
4-Layer glass lens | 120° | 4x
Video Codec
MJPEG
Video I Picture Format
Memory | Expansion
128 MB | up to 32 GB (SDHC, MicroSD)
Other features
Motion Detection, G-sensor, Electronic Image Stabilization, Cyclic recording
GPS sensor
Optional (for GPS model)
Microphone I Speaker
Built-in
USB 2.0
Power Source
Built in Re-chargeable battery (250mAh) or from Car Power Adaptor
Battery life
20 mins
Operation Temperature
0 °~ 45 °?
Dimensions/weight
82x55x20 mm I 90 g
In the box
Magnetic Cradle, Car Charger, USB Cable, Quick Start Guide, Warranty Card
Display Size
2.0" | 480x240 px
NT96223
Image Sensor
Video Codec
MJPEG
Memory | Expansion
Other features
GPS sensor
Built-in
USB 2.0
Power Source
Battery life
20 mins
0 °~ 45 °?
Dimensions/weight
82x55x20 mm I 90 g
In the box
Scroll to top
