BT.com
Wishlist
Prestigio RoadRunner 133 HD 1.5" DashCam with 16Gb SD Card and Motion Detection
Delivery
Standard Due date unavailable
GET EVIDENCE ON THE ROAD
Compact and affordable car video recorder with 1.5 inch LCD screen. The RoadRunner 133 records videos up to HD resolution, features cyclic recording and motion detection to provide additional safety when on the road. In addition it`s small weight makes it highly portable and almost invisible in the car.
HD QUALITY: The Camera records videos in up to HD resolution with pure sound and clear images, which captures every single detail of your trip
• BRIGHT 1.5-INCH TFT SCREEN: Easy to customize the image clarity, contrast and colour settings with a 1.5-inch LCD screen. Adjust the video recording quality as well as all additional parameters and operation modes with the user-friendly control panel
• MOTION DETECTION: in this mode, video shooting starts only when detecting a new movement in the frame. Consequently, it allows you to save the memory card for a longer video
• COMPACT SIZE: The Compact size and weight of only 44 g, makes the RoadRunner 133 highly portable and almost invisible in the car
• BEST VALUE FOR MONEY: Benefitting from the latest technology, high build quality and a stylish design at an extremely affordable price
Prestigio Roadrunner - dashboard camera
Dashboard camera
Widescreen Video Capture
Optical Sensor Type
CMOS
USB 2.0
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Focus Adjustment
Focus free
Display
LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* RoadRunner 133 HD DashCam
Reviewed by specop on 24/09/2016
Good price but, instructions are vague, took me an hour to sort of work out how to put it together. Still haven't worked out the "mode" control & it's not mentioned in instructions ? You'll need a card reader, to see the shots. The resolution is OK, but not good enough to read Licence plate on moving cars. For the price it's useful. Happy enough for the time being 'till I can afford a better one. Has a motion sense or constant record choice.
Scroll to top
