BT.com
Wishlist
PNY Quadro NVS 315 1GB GDDR3 PCI-Express x16 DDP
PNY Quadro NVS 315 1GB GDDR3...
£107.68
10 in stock
£107.68
Add to wishlist
Delivery
Standard 1-3 working days
The NVS 315 delivers exceptional flexibility and compatibility that lets you get the most from your existing display infrastructure. Drive all your DisplayPort, DVI, and VGA displays, regardless of display connectivity or chassis size. Even power two ultra-high resolution displays simultaneously at up to 2560 x 1600 using the NVS 315's proven combination of hardware and software.
Gather insights faster from an expanded workspace of multiple high-resolution displays and get three times more graphics cores than previous-generation NVS solutions for significantly improved visualization. Plus, take advantage of on-board frame buffer memory to interact with more visually compelling content on larger, high-resolution displays.
NVS boards are designed with simplified IT management in mind, including advanced tools that make integrating and maintaining a large-scale PC deployment fast and easy. Plus, they allow remote query and control of graphics and user display settings for systems spread across installations.
NVIDIA NVS 315 graphics card - Quadro NVS 315 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro NVS 315
1 GB DDR3
CUDA Cores
48
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
2048 x 1536
Max Resolution Details
DVI: 1920 x 1200 at 60 Hz / DisplayPort: 2560 x 1600 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
2
2 x DisplayPort - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
14.5 cm x 6.94 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
CUDA Cores
48
RAMDAC
400 MHz
Max Resolution
2
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, DTS-HD Master Audio support, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Dual-stream Hardware Acceleration, GPU Tessellation, Nvidia Unified GPU Architecture, HDCP
Size
1 GB
DDR3 SDRAM
Bus Width
64-bit
Bandwidth
14 GBps
Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3, Oracle Solaris, Windows 8
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
19.5 Watt
Low-profile bracket
1 x DMS-59 to 2 x DP cable
Software Included
Drivers & Utilities, Nvidia nView Advanced Desktop Software
UL, WHQL
14.5 cm
6.94 cm
Limited warranty - 3 years
£107.68
Save on this ideal PC Build kit!
Save £10.36
£127.23
Scroll to top
