Click to visit BT.com
BT.com
Wishlist
PNY Quadro K600 Kepler 1GB DDR3 128bit PCIE 2.0 LP DVI-I DP1.2
Quicklinx: 8LCMWS00
Mfr#: VCQK600-PB
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA Quadro K600
Interface: PCI Express 2.0 x16
Memory Size: 1GB
Digital Output: DisplayPort
1 due in 5-7 days
£144.62
The NVIDIA Quadro K600 graphics board offers great performance and outstanding features at an affordable price for a wide range of leading professional applications. You get 1GB of on-board DDR3 GPU memory, 192 SMX CUDA parallel processing cores, and full Shader Model 5 compatibility; all in a low-profile form factor for maximum system flexibility.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether it's product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster, more profitably, and with superior visual quality.
NVIDIA Quadro K600 graphics card - Quadro K600 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K600
1 GB - DDR3
CUDA Cores
192
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
2
DVI-I (dual link) , DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
16 cm x 6.89 cm
Package Type
Retail
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K600
CUDA Cores
192
RAMDAC
400 MHz
Max Resolution
2
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, NVIDIA Parallel DataCache, NVIDIA Mosaic, Shader Model 5.0, Nvidia 3D Vision Pro, TXAA, SMX technology, Nvidia Fast Approximate Antialiasing Technology (FXAA), Bindless Textures , HDCP
Size
1 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
29 GBps
SunSoft Solaris, Linux, Microsoft Windows Vista (32/64 bits), Linux (64-bit), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
41 Watt
Low-profile bracket, full-height bracket
1 x DVI-VGA adapter , 1 x DisplayPort-DVI adapter
Software Included
Drivers & Utilities
UL, RoHS
16 cm
6.89 cm
Package Type
Retail
3 years warranty
Service & Support Details
Limited warranty - 3 years
PNY Quadro K600 Kepler 1GB DDR3 128bit PCIE 2.0 LP DVI-I DP1.2 Bundle deal on PNY Quadro K600 Kepler 1GB DDR3 128bit PCIE 2.0 LP DVI-I DP1.2
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£164.15
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£154.61
8LCM C2G HDMI to DisplayPort Adapter Converter In Stock £46.15
8LCM C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £28.39
8LCM C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £22.83
8LCM C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £11.07
8LCM C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £17.44
8LCM C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £19.94
8LCM C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.97
Resources
The following resources are available for the PNY Quadro K600 Kepler 1GB DDR3 128bit PCIE 2.0 LP DVI-I DP1.2
Memory Size: 1GB
Brand: PNY
Price Range Inc VAT: 100 - 150
