BT.com
Wishlist
PNY Quadro K5000 4GB 256bit GDDR5 PCI Express 3.0 x16 DVI DisplayPort
Delivery
Standard Due date unavailable
The NVIDIA Quadro K5000 GPU leverages the new NVIDIA Kepler architecture to deliver the world's most compatible and power-efficient solution for accelerating professional applications. Count on the NVIDIA Quadro K5000 for exceptional design interaction with complex models, richer scene details and effects for content creation, and faster results when processing massive datasets for scientific exploration.
You can now drive up to four displays simultaneously with a single Quadro K5000. This makes it easy to deploy multiple displays across a desktop, build an expansive digital signage wall, or create a sophisticated stereoscopic 3D CAVE environment. Other NVIDIA technologies (Quadro Sync, Quadro Mosaic, and GPUDirect), coupled with a Quadro K5000, give you an easy way to perform image synchronization and resolution scaling of a synchronized display surface with multiple projectors or displays.
The next-generation NVIDIA Kepler architecture is built on a breakthrough streaming multiprocessor design, called SMX, which implements significant architectural advantages over previous generation products. These include substantial increases in per-clock throughput of key graphics operations that combine to deliver a new level of performance and power efficiency. The NVIDIA Kepler architecture also introduces the concept of bindless textures, enabling the GPU to reference textures directly in memory eliminating the limit on the number of unique textures that can be used to render a scene.
NVIDIA Quadro GPUs are designed, built, and tested by NVIDIA specifically for professional workstations powering over 200+ professional applications across a broad range of industries, including manufacturing, media and entertainment, sciences, and energy.
NVIDIA Quadro K5000 graphics card - Quadro K5000 - 4 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K5000
4 GB GDDR5
CUDA Cores
1536
RAMDAC
400 MHz
Memory Interface
256-bit
Max Resolution
3840 x 2160
Max Monitors Supported
4
DVI-I (dual link) , DVI-D , 2 x DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
26.5 cm x 11 cm
Package Type
Retail
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K5000
CUDA Cores
1536
RAMDAC
400 MHz
Max Resolution
3840 x 2160
4
API Supported
Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Nvidia SLI ready, Shader Model 5.0, Nvidia 3D Vision Pro, TXAA, FXAA, Dual Copy Engines, GPU Tessellation, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture, Multi-stream hardware H.264 encoder, Nvidia Quadro Digital Video Pipeline, OpenGL Quad Buffered Stereo Support, NVIDIA Maximus technology, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Bindless Textures, HDCP
Size
4 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
173 GBps
Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits), Windows 8 (32/64 bits)
122 Watt
6 pin power cable
1 x DVI-VGA adapter , 2 x DisplayPort-DVI adapter
Software Included
Display drivers
26.5 cm
11 cm
Package Type
Retail
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£44.23
£17.40
£9.80
£22.39
£12.42
£15.15
Scroll to top
