BT.com
Wishlist
PNY Quadro K4000 Kepler 3GB GDDR5 256bit PCIE 2.0 2xDP 1xDVI-I
Delivery
Standard Due date unavailable
The NVIDIA Quadro K4000 graphics board offers ultra-fast performance and visual quality enhancing technical innovations that take a wide range of leading professional applications to the next level of performance and fluid interactivity. You get 3GB of GDDR5 GPU memory, 768 SMX CUDA parallel processing cores, the ability to drive up to four simultaneous displays, and full Shader Model 5 compatibility; all in a single slot form factor requiring significantly less power than competing graphics products.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether it's product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster, more profitably, and with superior visual quality.
NVIDIA Quadro K4000 graphics card - Quadro K4000 - 3 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K4000
3 GB GDDR5
CUDA Cores
768
RAMDAC
400 MHz
Memory Interface
192-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
DVI-I (dual link) , 2 x DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
24.1 cm x 11.1 cm
Package Type
Retail
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K4000
CUDA Cores
768
RAMDAC
400 MHz
Max Resolution
4
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Shader Model 5.0, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, TXAA, SMX technology, GPU Tessellation, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, Bindless Textures, Multi-Stream Technology , HDCP
Size
3 GB
GDDR5 SDRAM
Bus Width
192-bit
Bandwidth
134 GBps
SunSoft Solaris, Linux, Microsoft Windows Vista (32/64 bits), Linux (64-bit), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
Additional power connector
80 Watt
1 x DVI-VGA adapter , 1 x DisplayPort-DVI adapter
Software Included
Drivers & Utilities
UL, RoHS
24.1 cm
11.1 cm
Package Type
Retail
3 years warranty
Service & Support Details
Limited warranty - 3 years
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£46.63
£28.68
£12.10
£23.62
£20.98
£16.84
Resources
The following resources are available for the PNY Quadro K4000 Kepler 3GB GDDR5 256bit PCIE 2.0 2xDP 1xDVI-I
Scroll to top
