BT.com
Wishlist
PNY Quadro K2000 Kepler 2GB DDR5 128bit PCIE 2.0 2xDP 1xDVI-I
Delivery
Standard Due date unavailable
The NVIDIA Quadro K2000 offers the perfect blend of performance and the latest productivity enhancing technical innovations at a very reasonable cost for a wide range of leading professional applications. You get 2GB of GDDR5 GPU memory, 384 SMX CUDA parallel processing cores, the ability to drive up to four displays simultaneously, and full Shader Model 5 compatibility; all in a single slot form factor which requires no auxiliary power to deliver full performance.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitions visions - whether it's product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster, more profitably, and with superior visual quality.
NVIDIA Quadro K2000 graphics card - Quadro K2000 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2000
2 GB GDDR5
CUDA Cores
384
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
DVI-I (dual link) , 2 x DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
20.2 cm x 11.1 cm
Package Type
Retail
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2000
CUDA Cores
384
RAMDAC
400 MHz
Max Resolution
4
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Shader Model 5.0, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, TXAA, SMX technology, GPU Tessellation, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, Bindless Textures, Multi-Stream Technology , HDCP
Size
2 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
64 GBps
SunSoft Solaris, Linux, Microsoft Windows Vista (32/64 bits), Linux (64-bit), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
51 Watt
1 x DVI-VGA adapter , 1 x Mini DisplayPort-DVI adapter
Software Included
Drivers & Utilities
UL, RoHS
20.2 cm
11.1 cm
Package Type
Retail
3 years warranty
Service & Support Details
Limited warranty - 3 years
Accessories
£26.26
£12.10
£21.42
£19.21
£14.58
Resources
The following resources are available for the PNY Quadro K2000 Kepler 2GB DDR5 128bit PCIE 2.0 2xDP 1xDVI-I
Scroll to top
