BT.com
Wishlist
PNY Quadro 2000D 1GB PCI-Express x16 DVI
Free delivery
Delivery
Standard Due date unavailable
Delivering the industry's best-in-class performance across leading professional ISV applications, the NVIDIA Quadro 2000D by PNY features two dual-link DVI connectors to drive two ultra-high-resolution panels and add flexibility for multi-monitor configurations. Professional applications can take advantage of the Quadro 2000D advanced feature set, including Scalable Geometry Engine technology, 192 NVIDIA CUDA parallel processing cores and 1GB of memory for fast processing of complex models and scenes.
The NVIDIA Quadro 2000D by PNY also delivers the industry's most advanced diagnostic imaging graphics solution. Offering two dual-link DVI connectors for display flexibility, support for 10/12-bit grayscale monitors up to 10Mpixels, and DICOM monitor calibration capabilities - the Quadro 2000D enables more confident medical analysis.
Based on NVIDIA's award-winning Fermi Architecture, the Quadro 2000D delivers advanced capabilities including 3D Vision Pro for high quality stereoscopic 3D environments and Mosaic Technology which enables any application to scale across up to eight displays using multiple Quadro graphics boards.
NVIDIA Quadro 2000D by PNY graphics card - Quadro 2000D - 1 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro 2000D
1 GB - GDDR5
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / VGA: 2048 x 1536 at 85Hz
2 x DVI-I (dual link)
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.0
17.8 cm x 11.1 cm
Package Type
Retail
3 years warranty
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro 2000D
Max Resolution
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA High Precision High Dynamic Range (HDR) Technology, NVIDIA Application Acceleration Engines, NVIDIA Mosaic , HDCP
Size
1 GB
GDDR5 SDRAM
Bus Width
128-bit
SunSoft Solaris, Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
System Requirements Details
Windows XP/Vista/7 - RAM 1 GB - HD 200 MB
17.8 cm
11.1 cm
Package Type
Retail
3 years warranty
Service & Support Details
Limited warranty - 3 years
Scroll to top
