BT.com
Wishlist
PNY NVIDIA QUADRO NVS 310 1GB DDR3 64-bit PCI-E X16 DUAL DisplayPort
PNY NVIDIA QUADRO NVS 310 1GB DDR3...
£92.22
31 in stock
£92.22
Add to wishlist
Delivery
Standard 1-3 working days
Boost your enterprise's productivity with the NVIDIA® NVS™ 310 dual-display professional graphics solution. This graphics board provides a reliable hardware and software platform to enable fast, cost-effective integration, deployment, and support across large enterprises. Each NVS 310 board features DisplayPort 1.2, NVIDIA Mosaic™ Technology, and NVIDIA NVIEW desktop management software, and can drive up to two 30-bit displays at resolutions up to 2560x1600 at 60Hz. This allows business professionals to maximize productivity by increasing their desktop real estate and leveraging advanced application-management tools. Plus, every NVS 310 is tested on leading business applications and designed with the ideal balance of performance and power to meet the needs of today's most demanding business user.
NVIDIA power management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability. PNY provides unsurpassed service and commitment to its professional graphics customers offering: 3-Year Warranty, pre and post-sales support, dedicated NVS Field Application Engineers and direct tech support hotlines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, Software installation disc and documentation to ensure a quick and successful install.
NVIDIA NVS 310 by PNY graphics card - NVS 310 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 310
1 GB DDR3
CUDA Cores
48
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
2 x DisplayPort
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.1, OpenACC
14.5 cm x 6.9 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 310
CUDA Cores
48
Max Resolution
2560 x 1600 at 60 Hz
2
2 x DisplayPort
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, Dual-stream Hardware Acceleration, GPU Tessellation, Multi-Stream Technology, linear pulse-code modulation (LPCM) support, HDCP
Size
1 GB
DDR3 SDRAM
Bus Width
64-bit
Bandwidth
14 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Oracle Solaris, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
19.5 Watt
Low-profile bracket
Software Included
Display drivers, Nvidia nView Desktop Management Software
14.5 cm
6.9 cm
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£44.58
£17.52
£9.80
£22.57
£12.42
£15.15
Scroll to top
