BT.com
Wishlist
PNY NVIDIA QUADRO NVS 310 1GB DDR3 64-bit PCI-E X16 DUAL DisplayPort/DVI-D
PNY NVIDIA QUADRO NVS 310 1GB DDR3...
£107.13
More than 50 in stock
£107.13
Add to wishlist
Delivery
Standard 1-3 working days
Fast 1GB DDR3 graphics memory
Delivers high throughput to simultaneously play stunning HD video on each connected display.
Intelligent Power Management
NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability.
NVIDIA CUDA
48 CUDA GPU parallel computing cores compatible with all CUDA accelerated applications. NVIDIA CUDA provides a development environment and tool suite that unleashes new capabilities to solve various visualization challenges.
Low-Profile and Flexible Form Factor
Simplifies IT administration and deployment throughout an enterprise. Regardless of desktop system (standard tower PC. workstation, small form factor system) or the display type (LCD, DLP, plasma) NVS 310 has the ability to fit into any existing installations without being disruptive.
Ultra-Quiet Fansink
Whisper-quiet 22 dba idle, 22.4 dba maximum at room temperature
Dual DisplayPort 1.2 Connectors
Supports ultra-high resolution panels up to 2560 x 1600 at 30bpp - enabling maximum range, resolution, refresh rate, and color depth designed to support the latest display technologies. DisplayPort 1.2 multi-streaming allows daisy chaining of compatible displays or attachment via DisplayPort 1.2 compliant hubs.
DVI-D Single-Link Connectors
Two NVIDIA NVS certified high-quality DisplayPort to DVI-D single-link adapters allow DVI displays to be driven at resolutions up to 1920 x 1200 at 60Hz.
NVIDIA High Definition Video Technology
NVIDIA high definition video technology is the combination of high-definition video processors and software that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing, inverse telecine and high quality HD video playback - with low CPU utilization and power consumption.
NVIEW Advanced Desktop Software
The NVIEW Advanced Desktop Software delivers maximum flexibility for single-large display or multi-display options, providing unprecedented end-user control of the desktop experience for increased productivity.
Multi-Display Experience with NVIDIA Mosaic
NVIDIA Mosaic enables seamless taskbar spanning as well as transparent scaling of any application across up to 8 displays. Works over multiple displays or one ultra-high resolution display using a single or multiple NVS graphics cards (Windows 8 and 7 only).
Unified Driver Architecture (UDA)
Part of the NVIDIA Forceware unified software environment (USE). The NVIDIA UDA guarantees forward and backward compatibility with software drivers. Simplifies upgrading to a new NVIDIA product because the latest driver supports all current NVIDIA products.
Compatible with Industry Leading Applications
Extensive compatibility testing ensures that NVS 310 provides a stable and reliable graphics platform for industry leading business applications including Microsoft Office, Adobe Acrobat, Lotus Notes, OpenText Exceed and Exceed onDemand, TradeStation, Reuters Financial Software, pcAnywhere, Internet Explorer 9, Firefox 4, and many other essential business and enterprise applications.
NVIDIA NVS 310 by PNY graphics card - NVS 310 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 310
1 GB DDR3
CUDA Cores
48
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
2 x DisplayPort , 2 x DVI-D (Single-Link) - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.1, OpenACC
14.5 cm x 6.9 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 310
CUDA Cores
48
Max Resolution
2560 x 1600 at 60 Hz
2
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, Dual-stream Hardware Acceleration, GPU Tessellation, Multi-Stream Technology, linear pulse-code modulation (LPCM) support, HDCP
Size
1 GB
DDR3 SDRAM
Bus Width
64-bit
Bandwidth
14 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Oracle Solaris, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
19.5 Watt
Low-profile bracket
2 x DisplayPort-DVI adapter
Software Included
Display drivers, Nvidia nView Desktop Management Software
14.5 cm
6.9 cm
Limited warranty - 3 years
PNY NVIDIA QUADRO NVS 310 1GB DDR3 64-bit PCI-E X16...
£107.13
Save on this ideal PC Build kit!
Save £10.36
£126.68
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£46.63
£28.68
£12.10
£23.62
£20.98
£16.84
Scroll to top
