BT.com
Wishlist
PNY Nvidia Quadro M4000 Graphics Card
PNY Nvidia Quadro M4000 Graphics...
£962.42
£962.42
Add to wishlist
Delivery
Standard 1-3 working days
Get real interactive expression with NVIDIA Quadro - the world's most powerful workstation graphics. Tackle your most demanding visualization workloads with ease using the advanced NVIDIA Maxwell GPU architecture and the flexibility of a single-slot form factor. 8 GB of ultra-fast memory enables the creation and rendering of large, complex models and the computation of massive datasets. A new display engine drives up to four 4K resolutions displays natively (4096 x 2160 at 60 Hz with 30-bit color). Pair up two or more outputs to drive displays greater than 4K, and take advantage of NVIDIA Quadro Sync support to frame-lock multiple displays together or use external I/O boards and NVIDIA's GPUDirect for Video to integrate the Quadro M4000 into broadcast, video or film production workflows.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
NVIDIA Quadro M4000 graphics card - Quadro M4000 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
8 GB GDDR5
CUDA Cores
1664
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
4 x DisplayPort , DVI-D (Single-Link) - with adapter
API Supported
OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
24.1 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
CUDA Cores
1664
Max Resolution
4
API Supported
Nvidia GeForce 3D Stereo technology, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, 16x angle invariant anisotropic texture filtering, ultra-quiet active fansink, 16K Texture and Render Processing, HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
192 GBps
Linux, Microsoft Windows Vista, Oracle Solaris, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM, Internet connection, 6 pin PCI Express power connector
120 Watt
6 pin power cable, stereo connector bracket
1 x DisplayPort to DVI-D (SL) adapter
Software Included
Display drivers
24.1 cm
11.2 cm
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£44.23
£17.40
£9.80
£22.39
£12.42
£15.15
Scroll to top
