BT.com
Wishlist
PNY NVIDIA QUADRO K6000 Sync 12GB DDR5 PCI-E X16 384-bit
Delivery
Standard Due date unavailable
The NVIDIA Quadro K6000 graphics card is the ultimate expression of NVIDIA's expertise in professional graphics, empowering artists, designers, and engineers to realize their biggest visions. It combines 2880 NVIDIA CUDA parallel processing cores, accelerated double-precision computation, plus the ability to drive up to four ultra-high-resolution displays or projectors. This makes the Quadro K6000 the superior choice to bring your largest and most complex projects to life.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
NVIDIA Quadro K6000 graphics card - Quadro K6000 - 12 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro K6000
12 GB GDDR5
CUDA Cores
2880
RAMDAC
400 MHz
Memory Interface
384-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , 2 x DisplayPort , VGA - with adapter , 2 x DVI-D (Single-Link) - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.3
26.7 cm x 11.1 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bundled with
NVIDIA Quadro Sync add-on interface board
Graphics card
Bundled with
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro K6000
CUDA Cores
2880
RAMDAC
400 MHz
Max Resolution
3840 x 2160
4
API Supported
Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, TXAA, FXAA, Dual-stream Hardware Acceleration, Dual Copy Engines, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, Kepler GPU Architecture, OpenGL Quad Buffered Stereo Support, NVIDIA Maximus technology, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Bindless Textures , HDCP
Size
12 GB
GDDR5 SDRAM
Bus Width
384-bit
Bandwidth
288 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Oracle Solaris, Windows 8 (32/64 bits)
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
225 Watt
Stereo connector bracket, 3 x 6 pin power cables, 6 cable retention clips
1 x DVI-VGA adapter , 2 x DisplayPort-DVI adapter
Software Included
Drivers & Utilities
26.7 cm
11.1 cm
Limited warranty - 3 years
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£45.34
£17.83
£9.80
£22.98
£12.55
£15.64
Scroll to top
