BT.com
Wishlist
PNY NVIDIA QUADRO K5200 Sync 8GB DDR5 PCI-E X16 256-bit 1*DL
Delivery
Standard Due date unavailable
The NVIDIA Quadro K5200 gives you amazing application performance and capability, making it faster and easier to accelerate 3D models, render complex scenes, and simulate large datasets. 8 GB of GDDR5 GPU memory with ultra-fast bandwidth allows you to create and render large, complex models and compute massive datasets. Plus, there's the display engine that drives up to four displays natively with DisplayPort 1.2 support for ultra-high resolutions like 3840 x 2160 at 60 Hz with 30-bit color.
The NVIDIA Quadro Sync board included as part of this turnkey solution synchronizes up to four NVIDIA Kepler architecture-based GPUs and up to 16 displays or projectors per system. Quadro Sync benefits include the ability to keep multi-projector systems or video walls free of imaging artifacts without impacting performance, the ability to align inputs for multi-input display devices like 4K projectors or panels, proper stereoscopic 3D display across multiple systems, and the ability to align displays or projectors to an external timing source. NVIDIA Mosaic technology support allows any application to scale across synchronized displays or projectors and offers features like projector overlap and an integrated geometry and intensity adjustment to enable pixel-accurate display surfaces.
NVIDIA Quadro K5200 Sync graphics card - Quadro K5200 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro K5200
8 GB GDDR5
CUDA Cores
2304
RAMDAC
400 MHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , 2 x DisplayPort , VGA - with adapter , DVI-D (Single-Link) - with adapter
API Supported
OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.5
26.7 cm x 11.1 cm
Package Type
Retail
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bundled with
NVIDIA Quadro Sync add-on interface board
Graphics card
Bundled with
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro K5200
CUDA Cores
2304
RAMDAC
400 MHz
Max Resolution
4
API Supported
Nvidia GeForce 3D Stereo technology, Nvidia SLI Multi-GPU Technology, Dual Slot Fan Cooler, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Hardware Video Decode Acceleration, Shader Model 5.0, Nvidia 3D Vision Pro, FXAA, SMX technology, Dual Copy Engines, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Bindless Textures, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
192 GBps
SunSoft Solaris, Linux, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8 / 8.1
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
150 Watt
Stereo connector bracket, 4 x cable retention clips, 3 x connector clips
1 x DisplayPort-DVI adapter , 1 x DVI-VGA adapter
Software Included
Drivers & Utilities
26.7 cm
11.1 cm
Package Type
Retail
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£44.58
£17.52
£9.80
£22.57
£12.42
£15.15
Scroll to top
