BT.com
Wishlist
PNY Nvidia Quadro K2200 4GB PCI-E X16 DDR5 DVI-I
PNY Nvidia Quadro K2200 4GB PCI-E...
£468.28
£468.28
Add to wishlist
Delivery
Standard 1-3 working days
The NVIDIA Quadro K2200 delivers exceptional power-efficient 3D application performance. 4 GB of GDDR5 GPU memory with fast bandwidth enables you to create large, complex models, and a flexible single-slot form factor makes it compatible with even the most space and power-constrained chassis. Plus, an all-new display engine drives up to four displays with DisplayPort 1.2 support for ultra-high resolutions up to 3840 x 2160 at 60 Hz with 30-bit color. Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
NVIDIA Quadro K2200 graphics card - Quadro K2200 - 4 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2200
4 GB GDDR5
CUDA Cores
640
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
3
DVI-I (dual link) , 2 x DisplayPort , DVI-D (Single-Link) - with adapter , VGA - with adapter
API Supported
OpenCL, DirectCompute, DirectX 11.2, OpenGL 4.5
20.2 cm x 11.1 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2200
CUDA Cores
640
RAMDAC
400 MHz
Max Resolution
3
API Supported
Nvidia SLI Multi-GPU Technology, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Hardware Video Decode Acceleration, Shader Model 5.0, Nvidia 3D Vision Pro, FXAA, SMX technology, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, Nvidia Quadro Mosaic Technology, Bindless Textures, Nvidia Temporal Anti-Aliasing Technology (TXAA), HDCP
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
80 GBps
SunSoft Solaris, Linux, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8 / 8.1
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
60 Watt
1 x DisplayPort-DVI adapter , 1 x DVI-VGA adapter
Software Included
Drivers & Utilities
20.2 cm
11.1 cm
ENERGY STAR Certified
Limited warranty - 3 years
£468.28
Save on this ideal PC Build kit!
Save £8.43
£487.50
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£45.34
£17.83
£9.80
£22.98
£12.55
£15.64
Scroll to top
