BT.com
Wishlist
PNY GeForce GTX 660 2GB PCI-Express 3.0 HDMI
Delivery
Standard Due date unavailable
  • NVIDIA® GPU Boost
  • NVIDIA TXAA technology
  • NVIDIA FXAA technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA Surround™ technology
  • Support for four concurrent displays including: Two dual-link DVI, HDMI, DisplayPort 1.2
  • Microsoft® DirectX® 11
  • NVIDIA PhysX® technology
  • NVIDIA 3D Vision®-ready
  • NVIDIA SLI Ready®
  • NVIDIA CUDA® technology
  • PCI Express 3.0 support
  • OpenGL 4.2 suppor
Performances Features
  • Bus connector : PCI Express® 3.0
  • Outputs : Dual DVI, HDMI, DIsplay Port
  • CUDA Cores : 960
  • Memory Capacity : 2 GB GDDR5
  • Memory Interface : 192-bit
  • Base / Boost Clock : 980 MHz / 1033 MHz
  • Memory Speed : 6 GBPs
  • Memory Bandwith : 144 GB/sec
  • FIlRate : TBC billion texels/seconds
Minimum System Requirements
  • PCI Express-compliant motherboard with one dual-width x16 graphics slot
  • One 6-pin PCI Express supplementary power connector
  • Minimum 450W or greater system power supply (with a minimum 12V current rating of 24A)
  • 300 MB of available hard-disk space
  • 2GB system memory (4GB or higher recommended)
  • Microsoft Windows 7, Windows Vista, or Windows XP Operating System (32 or 64-bit)
  • DVD-ROM drive or Internet connection
Packaging Contents
  • PNY GeForce GTX 660 graphics card
  • Driver CD
  • Quick Install Guide
  • Y PCIE Power Connectors
  • 3 Years Manufacturer Warranty
PNY XLR8 GeForce GTX 660 graphics card - GF GTX 660 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 660
2 GB GDDR5
Core Clock
980 MHz
Boost Clock
1033 MHz
CUDA Cores
960
Memory Interface
192-bit
Max Monitors Supported
4
2 x DVI , HDMI , DisplayPort
API Supported
DirectX 11, OpenGL 4.2
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
980 MHz
Boost Clock
1033 MHz
CUDA Cores
960
4
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, TXAA, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture
Size
2 GB
GDDR5 SDRAM
Bus Width
192-bit
Bandwidth
144.2 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Min RAM Size
2 GB
Min Hard Drive Space
300 MB
Required Power Supply
450 W
Additional Requirements
DVD-ROM, two 6-pin power connectors
6 pin PCIe power cable
Software Included
Drivers & Utilities
3 years warranty
Service & Support Details
Limited warranty - 3 years
Resources
The following resources are available for the PNY GeForce GTX 660 2GB PCI-Express 3.0 HDMI
Scroll to top
