BT.com
Wishlist
PNY GeForce GTX 1050Ti 1290MHz 4GB GDDR5 DVI HDMI DP
PNY GeForce GTX 1050Ti 1290MHz 4GB...
£148.38
£148.38
Add to wishlist
Delivery
Standard 1-3 working days
This advanced graphics card boosts performance in high-definition games, and delivers super-fast, smooth, power-efficient gameplay. You can even capture and share professional-quality in-game photos.
PNY GeForce GTX 1050 Ti graphics card - GF GTX 1050 Ti - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1050 Ti
4 GB GDDR5
Core Clock
1290 MHz
Boost Clock
1392 MHz
CUDA Cores
768
Memory Interface
128-bit
Max Resolution
7680 x 4320
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
3.958 cm x 17.8 cm x 11.2 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1290 MHz
Boost Clock
1392 MHz
CUDA Cores
768
Max Resolution
7680 x 4320 at 60 Hz
API Supported
NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GameWorks, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel, NVIDIA Pascal GPU technology, HDCP
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Required Power Supply
300 W
Additional Requirements
CD-ROM, Internet connection, 6 pin PCI Express power connector
75 Watt
3.958 cm
17.8 cm
11.2 cm
Limited warranty - 3 years
£148.38
Save on this ideal PC Build kit!
Save £8.29
£167.55
Scroll to top
