BT.com
Wishlist
PNY GeForce GTX 1050 1354MHz 2GB GDDR5 DVI HDMI DP
PNY GeForce GTX 1050 1354MHz 2GB...
Free Game
£124.28
Free Game
Limited Time Offer
Discover Indie! Get Maize, Redout, Or Raw Data FREE!
£124.28
Add to wishlist
Delivery
Standard 1-3 working days
This advanced graphics card boosts performance in high-definition games, and delivers super-fast, smooth, power-efficient gameplay. You can even capture and share professional-quality in-game photos.
PNY GeForce GTX 1050 graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1354 MHz
Boost Clock
1455 MHz
CUDA Cores
640
Memory Interface
128-bit
Max Resolution
7680 x 4320
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
3.958 cm x 17.8 cm x 11.2 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1354 MHz
Boost Clock
1455 MHz
CUDA Cores
640
Max Resolution
7680 x 4320 at 60 Hz
API Supported
NVIDIA Adaptive Vertical Sync, NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia Temporal Anti-Aliasing Technology (TXAA), NVIDIA GameWorks, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel, NVIDIA Pascal GPU technology, HDCP
Size
2 GB
GDDR5 SDRAM
Bus Width
128-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
71 Watt
RoHS, REACH
3.958 cm
17.8 cm
11.2 cm
Limited warranty - 3 years
£124.28
Save on this ideal PC Build kit!
Save £10.36
£143.83
Scroll to top
