BT.com
Wishlist
PNY Display Adapter - DVI-I (F) to Mini DisplayPort (M)
PNY Display Adapter - DVI-I (F) to...
£14.68
1 in stock
£14.68
Add to wishlist
Delivery
Standard 3-5 working days
The PNY Mini DisplayPort to VGA Adapter lets you connect a standard VGA monitor or projector, to a MacBook, MacBook Pro, or MacBook Air via its Mini DisplayPort. The MacBook, MacBook Pro, and MacBook Air laptops all feature a Mini DisplayPort port that allows you to connect an external display or projector using this adapter. You can use an external display as your main workspace or to extend your desktop. Connecting via the adapter will also allow you to work in mirrored mode with a projector so you can view on your screen what your audience sees.
PNY display adapter
Display adapter
Connector
DVI-I - female
Connector (Second End)
Mini DisplayPort - male
2 years warranty
Scroll to top
