BT.com
Wishlist
PMVmounts Universal Articulated Wall Mount Black 32"-47"
PMVmounts Universal Articulated...
£125.65
19 in stock
£125.65
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
PMV Mounts PMVMOUNT3246SA - mounting kit
Mounting kit - wall-mountable
Mounting Components
Articulating arm, mounting plate, 2 interface brackets
Adjustable Depth
13-70 cm
Tilt
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-46"
Flat Panel Mount Interface
200 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Mounting Pattern Size
680 x 475 mm
Max Load Weight
40 kg
Adjustable Depth
13-70 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
680 x 475 mm
32"-46"
Tilt
Max Load Weight
40 kg
Swivel adjustment
Scroll to top
