BT.com
Wishlist
Plustek SmartOffice PS506U
£633.72
£633.72
Add to wishlist
Delivery
Standard 1-3 working days
Enhanced with innovative features, the compact desktop SmartOffice PS506U features fast scanning speeds, a high daily duty cycle, robust paper handling capabilities, and an ultrasonic double-feed detection with outstanding image quality.
The SmartOffice PS506U features one of the most advanced document feeding and separation system in the industry. This system allows the SmartOffice PS506U to scan mixed batches of varying paper sizes and weights. Able to handle everything from business cards to rigid ID cards and documents, the SmartOffice PS506U easily scans both sides of one sheet in just one pass. The automatic document feeder (ADF) is also robust enough to feed up to three hard cards continuously or an embossed card up to 1.2 mm in thickness.
Plustek SmartOffice PS506U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
LED
Max Supported Document Size
244 x 2530 mm
United Kingdom
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
50 ppm (mono) / 45 ppm (colour)
Max Document Size
244 mm x 2530 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
6000 scans per day
Microsoft Windows 2000/XP/Vista/7, Windows 8
31.87 cm x 23.07 cm x 22.83 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
244 x 2530 mm
United Kingdom
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
45 ppm - portrait (front) / colour (back) - A4 - 200 dpi , 90 ipm - portrait (front) / colour (back) - A4 - 200 dpi , 50 ppm - portrait (front) / greyscale (back) - A4 - 300 dpi , 100 ipm - portrait (front) / greyscale (back) - A4 - 300 dpi , 50 ppm - portrait (front) / black & white (back) - A4 - 300 dpi , 100 ipm - portrait (front) / black & white (back) - A4 - 300 dpi
Scanner Features
Color Dropout, Blank Page Removal, automatic colour detection, Multi-Image Output, Auto Crop, Auto Deskew, Auto Document Rotation, UltraSonic Misfeed Detection, adaptive threshold processing
TWAIN, ISIS, WIA
Media Handling
Max Document Size
244 mm x 2530 mm
Supported Document Size Details
ADF - up to A4 (210 x 297 mm)
Automatic
100 sheets
USB 2.0
ENERGY STAR Certified
External power adapter
Software Included
Plustek DocAction, ABBYY FineReader 9.0 Sprint, Presto! BizCard 6, Presto! PageManager 9 SE, Plustek DI Express 6
System Requirements Details
Pentium 4 - 2 GHz HD 800 MB
31.87 cm
23.07 cm
22.83 cm
2.7 kg
Scroll to top
